Warrior cutting out...
I have a 1996 Warrior with a few mods. When I am any thing adove half throttle it cuts out, sputters, and just laggs. mods are listed in sig. any suggestions would help. the bike has great low end and will pull the tires in second from a roll, and im not exactly a small guy.
thanx |
Check your plug, sounds like you have a jetting issue.
If the safety switches on the clutch side are still there, I'd make sure they're workin. There's one for the clutch (can't start in gear without clutch engaged) and 1 for the parking brake. These engage the rev limiter if they are depressed or stuck in. Just check those two push button switches bfore you go any further. Haz
