how do i clean my carb?
someone i know said that my quad probs were due to a dirty carb. i was wondering where to start and how to get it apart.
I've seen a yfz and man they just look complicated to take apart !
all i have to do on my blster is unhook the carb from the manifold and the air intake and pop that baby out |
Dont know how to take it off, but make sure you dont use carb cleaner on the rubber parts of the carbs, that carb cleaner deforms the rubber!
do i use just a cloth if i get it apart somehow
They're just metal; don't be affraid of 'em.
Completely remove it from you machine and start taking the simple parts off - really. You'll learn about and understand them much better that way. Carb cleaner does a good job. |
It's also a great idea to have a maint manual handy. Exploded views can often times be very helpful. [img]i/expressions/face-icon-small-smile.gif[/img]
I throw my carbs in the washer twice a week. [img]i/expressions/face-icon-small-wink.gif[/img]
Originally posted by: sAyIt_fmf I throw my carbs in the washer twice a week. [img]i/expressions/face-icon-small-wink.gif[/img] |
Sometimes "bounce" other times "downy"...depends whats in the cubbard.
But to answer the real question...for the outside of the carb I use a hint of carb cleaner and a toothbrush....for the inside..carb cleaner also works...just not to heavy around any rubber or seals. (the cleaner can weaken it). I pull the jets and soak them. Any tight areas can be cleaned with dental picks. Thats about it...I try to stay away from compressed air. |
I find it hard to believe a 2004 is already dirty inside...
If you want to clean it This article will probably help carb cleaning and a diagram of your carb is here. carb |
