160-165 seems like too rich
Old Feb 22, 2004 | 03:47 AM
AustinONeal's Avatar
Default 160-165 seems like too rich
maybe you can help me back when i had 160-165 mains and a #25 pilot in it just seemed like it was running to rich like big time i have open exhaust and open airbox lid and i thought it was rich because when u started it it would blow a cloud of black smoke
Old Feb 22, 2004 | 05:20 AM
Yamaha660R's Avatar
I would think 155/160 would be right. That is what Alba sent me for my set up. Open lid and their pipe.
Old Feb 22, 2004 | 11:18 AM
warrior007's Avatar
I run 160-165 on one of the bikes with alot less mods, this one likes to be run rich. I believe we might be a lower elevation than OK.
Puffs on starting could be the float level or pilot. Whats your airscrew set at? is the choke on?
Old Feb 22, 2004 | 01:54 PM
ccgrady's Avatar
Im at 6200 feet with a 686 kit and i run 160 155's, 25 piolet with clip in middle.
Old Feb 22, 2004 | 10:43 PM
no the choke is not on. im setting at 3 turns each on the a/f mix and 148 150 third clip
stock pilot but i had a # 25 took it out
floats lever is set to what sixsixt said with the whole tube thing
Old Feb 23, 2004 | 10:55 AM
also should i leave the stock pilot or go back in with the 25's
Old Feb 23, 2004 | 11:10 AM
sixsixT's Avatar
If your going to run with the lid off I would use the 25 pilots and 2 1/2 L 2 3/4 R turns out on the mixture screws.
Old Feb 23, 2004 | 11:15 AM
What mains should i use with the 25 pilots and 2 1/2 L 2 3/4 R turns out on the mixture screws
Old Feb 23, 2004 | 11:26 AM
sixsixT's Avatar
Which end cap are you using? If it's the big one 165/170 MIKUNI.
Old Feb 23, 2004 | 11:27 AM
im not using a spark arrester straight through
