restrict my raptor
Old Feb 27, 2004 | 05:15 PM
rndlllee's Avatar
Default restrict my raptor
hi all i know it sounds mad but i need my 04 raptor restricted to meet the road law requirements of 15 kw instead of 33.5 kw can anyone help on how to do this please.
Old Feb 27, 2004 | 05:51 PM
HoundDog06's Avatar
Welcome to the forums.
Well, you are gonna have to help me out on a kw. That is a sound level right? Most forum members, like myself, are from the US and use the SAE units of decibel (db) for sound level. Am I correct in thinking your question is how to quiet your bike?
~HoundDog
Old Feb 27, 2004 | 06:04 PM
AngryHampster's Avatar
~HoundDog
i almost want to say kw is their HP rating system.
Old Feb 27, 2004 | 06:13 PM
rndlllee's Avatar
no m8 its the max net engine power ,
its the power i need restricting (bhp) the raptor as standard is 52 (bhp) (hp) which is 33.5 kilowatts in power which i need reduced to 15 kilowatts to pass road legal laws to get my number plates from my local vehicle licence station i need signed paperwork to say the quads been restricted .
any help whould be great
Old Feb 27, 2004 | 06:30 PM
the only way i can think of doing it is putting some kind of throttle limiter that stops you from taking it to redline.
Old Feb 27, 2004 | 07:01 PM
bansheeguy13's Avatar
CANT YOU JUST TURN THE SCREW ON YOUR THROTLE IN I MEAN THAT IS A WAY OF LIMITING YOUR MACHINE
Old Feb 27, 2004 | 07:08 PM
Outlawlawndragster's Avatar
restrict the exhaust and jet it down .
Old Feb 27, 2004 | 07:40 PM
Ward660R's Avatar
This seems like the only real logical way to accomplish that. The easiest way I can see to do it would be to put in a restirctor plate inbetween where the exhaust bolts to the head. Maybe use a thin peice of stainless steel, cut in a circle the same size as what the OD (out side diameter) of the head pipe. Then drill a hole in it, just as a guess 7/8 of an inch, and slip it between the heap pipe and the head. Then rejet like he said.
Old Feb 27, 2004 | 10:03 PM
Might try some washers in the very end of the pipe that way you at least have the full exhaust system for expansion you could also try restricting the intake but you need to stay back away from the carbs so they draft right
I wonder what would happen if you blocked one carb off and only ran on one side ? HMMMMMMMMMMMM
Old Feb 27, 2004 | 11:03 PM
Rider1169's Avatar
well, the first thing you HAVE to do is bore it to a 950. then take off you pipe completely, and put blinkers on it. then its road legal. top speed of about 55mph. intake might also help.
