Lights / Candlepower Kodiak
Does anyone know what candlepower in the stock Kodiak lights are?
I'm looking at the Moose lights and they are 120,000 candlepower, I wanted to guage them against the stock lights to see if it is what I want? |
Due to the extensive levels of lab work to obtain candlepower readings, it's probably just easier to gauge the brightness via wattage. Those little Moose lights a some nice additional lights to have. I think PIAA's, Hella's, or KC"s will probably give you quite a bit more bang for your buck. Don't forget to calculate the wattage output of your stator so you still have juice left over to recharge your battery. [img]i/expressions/face-icon-small-smile.gif[/img]
That is on my mind,, But I guess I can use at least 120 watts,, I believe that is what the accessory outlet is rated at ,, that I do not use....
Camo, I was looking at your photos and was wondering if you got your rear rack extension from the dealer or aftermarket and what did it cost? AlaskaBoy.
I got it from the Dealer,,, I think it was $80.00
I got the one that matched the racks ,,(wrinkle finish). |
