ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   It's gone again :( (https://atvconnection.com/forums/yamaha/155975-its-gone-again.html)
RoostItUp May 22, 2004 09:28 PM
It's gone again :(
Well...I took my bike out to the coast today after tightening my head down (which did fix my coolent leak), getting new tie rods, regearing, and new paddle tires.
After the second run up the face I noticed that the bike started vibrating a little more than usual. I just figured it was the new 10 paddle haulers I bought making more vibration but then the fun noise started happening, a VERY LOUD knocking coming from the bottom end. After that I shut it off ASAP and had a friend tow me in. The bike runs and starts perfect but when it is running it vibrates hard and knocks VERY loudly, does anyone have an idea what might be causing this problem?? It runs through all the gears in the tranny, so I think it's fine there. I was thinkin it might have to do with the crank...I hope this isn't gonna be expensive.
I'm getting sick of this Rappy breaking down all the time now...I think I'm gonna plan on selling this after I get it fixed and ridden a few times then plan on buying a new '05 YFZ and LEAVING THE ENGINE ALONE. Whens the info on the new models comin out and what is the date of the release?
Yamaha660R May 22, 2004 09:51 PM
It's gone again :(
The new Yamaha info will be released in Vegas on the 15th of June I think, and the new models come out July/August.
You may have spun a crank bearing, if I had to guess.
RoostItUp May 22, 2004 09:53 PM
It's gone again :(
Thats exatcally what I was thinkin...what generally causes that?
I know if you are out of oil or if oil isnt getting there it can cause that but I let it idle for a half hour after I tightened the head bolts and it ran perfect, so I don't think oil was a problem.
wshrdskin May 22, 2004 09:56 PM
It's gone again :(
Probably a crank problem. Didn't you install a carrillo rod the last time your engine went away? Just asking, seems I recall that's what you did anyway. I understand about your feelings of always fixing the Raptor.
Yamaha660R May 22, 2004 10:06 PM
It's gone again :(
If you replaced the rod and had the crank balenced you should have had new crank bearings. But general wear will cause them to spin. When I had miine done, my Raptor had 40hrs on it, and the right bearing was already catching and showing wear. So they just generally wear out from what I can tell.
sixsixT May 22, 2004 10:07 PM
It's gone again :(
Sounds like the rod or wrist pin. [img]i/expressions/face-icon-small-sad.gif[/img]
RoostItUp May 22, 2004 10:19 PM
It's gone again :(
Ya, I put the carillo rod in and had the crank balanced so I assume new bearings got put in. How much other damage would something like this cause? How much is it to fix this type of problem? Like I said, it still runs just doesn't sound good AT ALL.
bluethunder May 22, 2004 10:19 PM
It's gone again :(
Sorry too hear that man,i hate hearing anybodys quad break.It can be expemsive. Everytime i hear this stuff , It makes me more afraid too get inside my motor too do mods.
Hayseed May 22, 2004 10:32 PM
It's gone again :(
It can be expemsive. Everytime i hear this stuff , It makes me more afraid too get inside my motor too do mods.[/quote]
I heard that.
Yamaha660R May 22, 2004 10:36 PM
It's gone again :(
We can guess all night but you won't really know till you tear it apart. If the crank bearing spun then the only expensive part will be tearing the entire motor down and splitting the cases. But I would assume that the bearing that is pressed onto the crank with the rod would be new, but they may have sent you your original bearing on the other side of the crank.
The sooner you tear into the motor, the quicker you will find out what it is. But I swear it sounds like a crank bearing...does the motor shake or vibrate now?
© 2026 MH Sub I, LLC dba Internet Brands
