If raptor weighed the same as yfz...
i think the yfz is more like 30s stock if that and i also think it takes after the wr motor more than the yz,and i know the raptor stock makes 31hp and if it was lighter than the yfz or equal im sure the raptor would be able to be right up there with the yfz...
Originally posted by: yamiridr
30 your kidding. it has hp in the mid to high forties, easy
the dirtbike has over 50 stock the original yz400 had 45
The Stock-Bore champion at last years MLK drags only made 48 RWHP on Kenz dyno and it had extensive porting, cams, a bigger carb, and a ton of compression. In the real-world, they typically dyno around 33-35 stock. Which is about the same as a stock Raptor. So if they weighed the same, the Raptor's higher torque would easily overpower the YFZ.
