Ok guys, Getting ready to give the Banshee a big pick-up, What do i need?
Right now I have Toomey T-5's, K&N, Boyseen Reeds.
Ok i know i'm going to need 34 mm carbs. I got them spotted and found a place thats cheap on them. But what about pistons? I'm going to be spraying alot of Nitrous on it. I'm not sure on what crank? I definately want to get port work done on the head. Whats the best and most reasonable priced place to get my head ported.
What im looking for is to have one of the Baddest quads in my small area. We have some Banshee's that are running some 7.30s-7.80's 1/8 on asphault. Also a YFZ that is running 7.90's on alcohol. I want to bust him real bad.
What do i need to do what im wanting? Now this with'in a reasonable budget. Just a regular working guy, but i dont mind spending money on it as long as its on the right stuff to make it go!
Help me out ATV Connection Readers!
You should look into Vito's performance. A couple banshee's from here have work from them and they scream. Trinity also has several banshee engine kit's, and most of them giddy-up pretty good. It don't take a whole lot to make a banshee fast, and the NOS will really help if you set it up right. Don't cut corners in building your engine either. If you build it right it will save you future headache's.
If you want to go fast...... first start with porting...... there are a ton of awesome shops out there (Dan Hull,KT performance,Dune trash,White Knuckle Racing,DirtWorx.... and the list goes on and on! Ill make you a list of some good starting points! 1.get her ported 2.mill the head or get an aftermarket 3.ask the builder of choice which piston would be good for spraying....... the list could go on but first you need to find a good idea on how much you wanna spend then i could have a good idea for ya! you could go from a high rev 350 all the way to a triple ported 520 t rex with powervalves and override.....the skies the limit on a banshee its just depends on your budget!
give dirtworx a look! www.dirtworxracing.com i know the owner and he builds some sick banshees for reasonable prices!
Thanks...
The main thing i wanted to find was someone that could do some good port work. And kind of lead me in the right direction on what motor mods to do for what im wanting. I'll give them a call tommorrow....Thanks
Who should i ask for there?
Mphillips
07-29-2015 08:53 PM
