Trading in 00 Mod Banshee
I was going to trad in my 00 Mod Banshee for a 05 LE YFZ 450. But they only want to give me $2500 for it.
Here is what is done to it FMF Fatty Pipes & Power Core 2s Cool Head with 21cc domes Race Logic Porting Vitos Power Pistons 28mm Flat side Carbs V-Force Delta 2 Vitos Degree key Boost Bottle Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Pro Flow kit 6 Filtered Air Vents Laegers Pro-Trax +2 A-Arms Laegers Pro-Trax Swing Arm PEP Steering Stabilizer Work Ultracross Rear Shock Custom Axis Dual rate front Shocks Internal Thermal Water Pump Cover High Volume water Pump Aluminum Dipstick 20 Fin super Cooler Hinson Clutch Cover Rad Racing Axle Carrier X33 Dura Blue Axle Renthal Handlebars Pro Design Kill Switch Nacs Black Number Plate with white Number 1 Nacs Decal Kit Aluminum Silencer Hangers Dure Blue Posi-Lock Axle Nut PEP Clutch Lever Pro Design Power Shifter FootPag Extenders GaryDon Nerf Bars 15/41 Gearing ITP Race Rims Razr 2 Rear Tires Razr Front Tires Twist Throttle DG Front Bumper AC Swingarm Skid Plate Diamond Plate Chassis skid Plate Nacs Mag Cover Nacs Water Pump Cover Nacs Kick Starter Nacs Parking Brake Block Off Nacs Front & Rear Master Cylinder Cover Maier Race Cut front Fenders (Red) Maier Rear Fenders (Red) Maier Gas Tank Cover (Black) Maier Radiator Cover (Black) Nacs Yellow Handlebar Pad Moose Black Shock Cover EBC Brake Rotor Yellow Hurricane Grips Yamaha LE Banshee seat Red Grease Zerk Dust Caps Yellow/Black/Red Headlight Covers (Eyes) Aluminun Exhaust Clamps Toomey Radiator Aluminum Gas Cap Aluminum Handlebar Clamp X Ring Gold Chin High Output Stator Cascade Chain Slider (Yellow) I thank that is it |
what! i'll give ya 500 more for it.
We are going to try to sell it out right for $5000
sounds like a good plan
This Banshee Is Fast and has alot of power but I like the 05 LE YFZ 450
i think your goin to miss the sounds, smell, and powerband hit of it. if you traded it into your dealer they would give ya 2500 for it but then turn around and sell it for like 7g. i've seen it done before.
You'll be back. $crew the dealer part it if you dont want it.
I am not going to trad it in I might try to sell it out right. I dont want to sell it but we have been having this problem with it when it is Cold or warm it will run like $hit and when it is hot it runs real good the plugs are a Nice Brown Color and it is getting gas. We just cant find out what is the Problem with it.
It is the Left side we are have Problems with |
Your Shee is paid off right? Maybe you should keep it! There's nothing quite like a Shee!
Still have all the stock parts? put all of them on then sell the other stuff seperate.
