Warn 424 mounting on Wolverine?
I drilled the plastic on mine but not where the pictures in the instructions showed.
I put it on the right side in the flat on top of the gas tank just where the handlebars barely miss it.
It looks a lot neater to me there and since it is on the right I have to turn loose the throttle to engage it which means it is pretty much a sure thing the rear tires wont be spinning and clash any gears.
Originally posted by: OhHell
I drilled the plastic on mine but not where the pictures in the instructions showed.I put it on the right side in the flat on top of the gas tank just where the handlebars barely miss it.It looks a lot neater to me there and since it is on the right I have to turn loose the throttle to engage it which means it is pretty much a sure thing the rear tires wont be spinning and clash any gears.
Originally posted by: Daranello75
Do yyou have any pixs of your instal? I want to do the same thing as you did
I dont have any on file right now and its dark.
Send me your e-mail and I will take a couple and send to you tomorrow.
I dont have any on file right now and its dark.Send me your e-mail and I will take a couple and send to you tomorrow.
Originally posted by: OhHellI drilled the plastic on mine but not where the pictures in the instructions showed.I put it on the right side in the flat on top of the gas tank just where the handlebars barely miss it.It looks a lot neater to me there and since it is on the right I have to turn loose the throttle to engage it which means it is pretty much a sure thing the rear tires wont be spinning and clash any gears.
Jeff Roper
02-01-2022 11:48 AM
