Raptor's grounded
Okay so I bought this speedo(don't ask me why) and I was going to put it on tonight with my dad. Anyways, we take the wheel off and start to take off the rotor but we got stuck there. You see we can't get the rotor off because of the brake thingy(i'm really bad at mechanics). And we can't get the brake thingy off because of the rotor. Is there anyone who knows what i'm talking about and can help or give me a differant solution. Thanks[img]i/expressions/face-icon-small-confused.gif[/img]
No, front, confused and your right. we got it so the thing that holds the pads is loose, but there is this little peg that keeps it from pulling off the side of the rotor, make any sense?
youll figure it out
It's easy, just like a front wheel drive car. You take the 4 lugs loose, pull the wheel. You have two bolts on the inside of the caliper. Take those off and your caliper slides off the rotor. Let it hang, and if you need any more taken apart (Shouldn't), then pull the pin and the large nut loose on the middle of the 4 lugs and the rotor will slide off the spindle. Easy enuff?
