has any one ever tried 92 octain in a wolverine?
#22
Originally posted by: wolverine68
The octane rating refers to the fuels ability to resist ignition. The higher the octane rating, the harder it is to ignite. The higher octane fuels are necessary to resist auto-igniton (pinging or knocking) before the spark from the plug ignites the mixture. In a cold engine(like our canadian winters)you need a mixture which is easy to ignite. I admit the difference (for starting) is very slight and/or undetectable in most situations.
#23
Originally posted by: 4buy4
Octane rating refers to the fuels ability to resist PREIGNITION !!!!!!!!! That in turns will cause knock , ping ,,,,,,,,,,,,,,,,,
#24
The word pre ignition means ignition that takes place before the ingition event occurs [ spark that is ] !!!!! Preignition is usually caused by hot spots in a combustion chamber or a severly over heated engine . The prefix PRE means before as is taught in elementary school ,,,,,,,, look it up . The hot spots can be caused by heavy carbon deposits , sharp edges , etc , etc adnauseum . The real benefit of high octane gasoline comes into use when high compression and advanved timing is used to enhance performance . I am not going to get into pizzing contest with you , the info I just offered is common knowledge to any well informed technician ,,,,,,,,,,,,,,,,,,,,
Gman
Gman
#25
Nice reply...
Look, preignition implies a standard of ignition. You are getting hung up on the english here. I wont get into a pissing match with you either, nor will I try to add credibility to myself by saying I am a technition. Unless you are a gasoline technition, it doesnt mean jack.
The octane rating of gasoline tells you how much the fuel can be compressed before it ignites. When it ignites, that is ignition. To have preingition, you would have to have ignition correct? Yes, so when they test gasoline they compress it until it ignites. The measure of its resistance to ignition is its octane rating.
#27
I am likewise not a technician, nor am I looking for a pissing match. I beleive we are saying the same thing. Whether the the fuel is resisting pre-ignition or ignition is all the same to the fuel. It's the engine which may have the problem with pre-ignition and thus would require a higher octane fuel. With the octane rating, what you are actually talking about is the fuel's auto ignition temp( the lowest temp at which the fuel will self ignite). Compresion of the fuel creates heat causing auto-ignition. Beleive it or not you cannot ignite standing fuel with a burning cigarette...it's not hot enough but a spark, even static discharge will do it (kids don't test this at home.. or anywhere else). If you want a really high octane fuel to run in your machine run diesel.
[img]i/expressions/face-icon-small-wink.gif[/img]
