differential oil coming through the vent hose?
Old Nov 1, 2004 | 09:05 AM
Bruin3504x4's Avatar
Default differential oil coming through the vent hose?
Hi All, I have a 2004 Yamaha Bruin 350 4x4 and I noticed that there was some differential oil coming through the vent hose under the seat. Has anyone else experienced this? Is it normal?
Thanks,
Guy
Old Jan 24, 2005 | 06:31 PM
IdahoRider's Avatar
I think I am seeing the same thing on the two Bruins I own. The oil is accumulating on the throat of the air filter case. Seems to only be doing this in the cold weather. Didn't see any problem during the summer.
Old Jan 24, 2005 | 07:11 PM
WolverineMan15666's Avatar
I had the same problem with my '98 Wolverine. I noticed it did it more during cold weather when I rode it fast. The gear oil is thicker when its cold. It didn't cause any problems coming out of the vent hoses, but that stuff sure does stink. Just check the fluid level once in a while, everything should be OK.
Old Jan 24, 2005 | 07:19 PM
IdahoRider's Avatar
Thanks !!
Old Jan 24, 2005 | 11:11 PM
trahsub's Avatar
I think I had this exact thing happen on my 2004 Wolverine. I had a large accumulation of red oil in my intake box, I thought it was from the intake, should I check the level? What level should the diff be at???
Old Jan 25, 2005 | 09:09 AM
95Wolverine's Avatar
Differential fluid level should be just a little under the threads of the fill plug hole. If you actually fill it to the bottom of the threads as Yamaha states, you end up with the topic of this thread. I've let mine "burp" until it's happy, then checked it and try to never fill it above that "memorized" level. No problems since.
Old Jan 25, 2005 | 10:36 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
Might be Condinsation frezzeing up in the tube if it cold outside.
Old Jan 25, 2005 | 11:07 AM
trahsub's Avatar
Is diff fluid red??
Old Jan 25, 2005 | 01:19 PM
wolverine68's Avatar
Search "wolverine gear oil" in the Yamaha forum (Jan2/05) for more info on this.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 25, 2005 | 04:22 PM
The gear oil should be greenish colored. It also stinks. It kinda turns my stomach to smell it. The red oil you are finding might be excess air filter oil. If you spray too much oil on your airfilted you may be seeing that.
