best/cheapest/noticeable upgrade for a raptor660
One of the cheapest things you can do to effect the performance of your raptor is proper gearing for the type of riding that you do most.For most situations gearing down would be the best way to go but just how low depends on your typical days ride.Just in case you dont know a chain that is even a little too tight can slow you down and it can also be very hard on bearings and chains so that is another area to look at.Proper tire pressure is also an often overlooked factor that can have a huge effect on handling and performance.These items may seem insignificant when looked at individually but when you add them all up they can make much more of a difference than most would think.
Originally posted by: dman4quads
take of the front tires remove the valve stem cap put four washers on each stud put tires back on with valve stemfaceing inward washers help valve stem clear caliper total cost 2.00 increased front end 4 inchs see doug gust web sight it shows how many models u can do this on.
You will notice more of a stablity difference if you add spacers to the rear wheels.
