Raptor Floods When Leaning Right.
my 660 raptor pops and floods itself when it leans towards the right hand side. does that mean the right carburetor is messed up? if it is even idling and sitting on flat and i wobble it back and forth very quick it floods and stalls.???
Check the floats. I'm sure they are off. Buy a piece of clear tube that fits on the bottom drain spout on the bowl and put it on the spout and hold the other end up. Open the drain screw and check how high it is. It is the easiest way to find out which one it is. It should be about 3mm above the mating surface of the bowls to the carbs.
Hope it helps. |
