ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   banshee swing arm bolt won't drive out, help!!!! (https://atvconnection.com/forums/yamaha/182738-banshee-swing-arm-bolt-wont-drive-out-help.html)
quadfever54 Dec 7, 2004 12:31 AM
I can't get the swing arm bolt to break lose, the nut is off and when I try to drive the bolt out it does not budge, wondering if the bushings have worn a groove that may be hanging it up. any suggestions????? please
pendejo Dec 7, 2004 03:18 AM
If you haven't tried already, spray a alot of WD-40 in there and let it sit for about an hour, than spray it again, get a small diameter(sp?) piece of solid steel(I used a piece of rebar) about 2 ft. long, get a big azz hammer and let 'er have it. If that doesn't work, you could try heating the outside of the "housing" and try hammering it out. These things have a tendency to be a b1tch to get out. I've seen someone have to actually cut the bolt before. When you do get it out, clean that thing up really good with some high grit sand paper, and use plenty of lube when reinstalling.
© 2026 MH Sub I, LLC dba Internet Brands
