240 vs 400ex
a blaster with a vittos 240 kit piped and jetted vs a 400ex stock...drag and trails?
240 vs 400ex
you better smoke that 400ex in a drag, trails? thats tuff, the stock blaster suspension sucks balls.
240 vs 400ex
Drag race, you sure would give him a tough fight, it depends how good your 240 was build. For trails, if your a better rider, you will be able to handle the crappy suspension on the blaster, if not, say bye bye to the 400.
240 vs 400ex
the 240 will wreck the 400 in a drag. On trails....the suspension isn't the greatest, but i think you'll have no problem rippin azz comin out of the turns and burning the 400
240 vs 400ex
well hear is results from a actually waved drag
2001 blaster with fmf gold series, and turbine core 2, no airbox snorkel, jetted to perfection wiseco .020 over piston, reed spacer 20 inch tires. vs. 2001 400ex with Dg bumper Dg full skid plates 20 inch tires the blaster and 400 were dead even till second gear, from the holshot , then the 400 quickly walked on the blaster as soon as i hit 3rd gear, by 4th i was gone and didnt need 5th. blasters are quick tho just dont have a good topend, it seems when you hit 5th gear they level off, as compare to a warrior it keeps pulling the gear. v581 |
240 vs 400ex
The fastest Blaster I've seen was built pretty good (don't know what all) and the kid weighed like 75 lbs. I had no problem with it but it was giving some of the other 400s (EXs and Zs) a good run for about 200ft then they would catch it.
240 vs 400ex
No, A stock vitos 240 WILL NOT beat a 400ex, or Z400. Those kits come with no port work at all which is what really makes the power. The extra CC's actually do very little without the increased flow from port work and a larger carb. It can be done tho, mine walks all over 400's..easily.
240 vs 400ex
nice quad shavo
240 vs 400ex
Shavo, quick question, can a blaster be made any bigger then a 240cc? My last time out riding some guy was claiming he had a 270cc blaster, the thing was flying, but i doubted the size of the motor.
240 vs 400ex
the biggest ive seen is a 290
