warrior/wolverine head 2 questions
Old Dec 31, 2004 | 08:18 AM
todster's Avatar
Default warrior/wolverine head 2 questions
im looking to put a bigger carb on my wolverine i have read the warrior carb or edelbrock carb may work . the carbs are both 36mm? compared to my 34 stock and require a larger intake boot,my question.-- is the intake port on the head of the wolv the same size(not bolt pattern) as the warrior or will i need to enlarge the port on the wolv to match the new boot? 2nd im looking for bottom end power do you think a carb with a acellerator pump would be better or worse,i went threw the forum and not much on the results with a 366cc engine.
Kyle5050
Dec 13, 2019 04:25 AM
MNatv89
Aug 10, 2015 02:20 PM
toonces
Aug 5, 2015 05:55 PM
Bulgin88
Aug 1, 2015 06:39 PM
coolguy420
Jul 28, 2015 01:54 AM
