New Y2K Kodiak Owner
Old Sep 13, 2000 | 10:52 AM
KodiakDAT's Avatar
After reviewing all of the information I could find on various sport/utility quads I picked a Green 2000 4x4 Kodiak. Much of the information that swayed my final decision came from the reader’s comments on this site. I feel for the riding and work I will be doing with this quad I have made a choice and am very happy with the quad so far.
However, the shocks are squeaking something fears. I am wounding if this is a common problem with the Kodiak? Plus what others have done to correct this problem.
Old Sep 13, 2000 | 12:13 PM
frano's Avatar
I also have a 2000 Kodiak and love it. I took delivery on 6/15/00 and solved my squeek by applying WD 40 on the front shocks, shock mounts, and A frame mounts. Don't know where the squeeks were really coming from, but the WD has eliminated any squeeks for 3 weeks now. The only negative about the quad is I've had to replace all 3 sets of brake pads because of excessive wear after about 500 miles. The brake pad wear seems to be a common complaint. Ride on!
Old Sep 13, 2000 | 10:34 PM
therock's Avatar
The shock sqeeking is common on the Y2kodiak. The solution is easy. Loosen the bottom mount by 1\8 turn or 1 flat. It will go away forever and the shock will still be fastened tight.
Somthing else to look at is all the air duct connections for the belt housing cooling, intake and exhaust. The hose clamp type fasteners on some shipped too loose letting water in the housing. Make sure they are snug.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
YankeeRebel
Oct 6, 2015 06:44 AM
Ahtatu
Sep 28, 2015 12:14 PM
