IT'S RUNNING. just need to break it in!!!!
Can't wait to break it in and see how I did. It started right up. I do have a question about the stage 2. I will check my valve clearance again but it sounds louder then the stage 1 I had in. I did the specs hot cams gave (.20 & .25mm) and it is more clearance then I used for the stage 1(.13 & .18mm). Where should I be?
Congrats Dave !! Do you think you might have it dialed in to make it to Glamis this weekend?
On the specs I would adjust the valves per hot cam specs break it in and check them after the break in. |
Wish I could, but not going to be able to make it. My next trip is planned for the 29th at Gordon's. That's seems so far away.
UPDATE: I snuck out saturday to Gordon's to break her in. Motor worked great, but the clutch was slipping (you know to much pwer) Ha. Will change that this week, so I'll be ready for Gordon's this weekend. [img]i/expressions/face-icon-small-happy.gif[/img]
| All times are GMT -5. The time now is 08:36 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
