grizz in deep snow, should I be worried
Old Jan 24, 2005 | 01:36 PM
Sluggo312's Avatar
Default grizz in deep snow, should I be worried
Hey, I just read the post that I pasted at the bottom of this message. I was out riding in the deep snow yesterday and when I was done just parked in my garage...no heat in the garage. I'm new to atv riding so help me out here. Should I be worried...should i have done some maintanance before putting it away...is there something I should do tonight so that it'll be ready for a weekend of riding at the end of the week.
thanks
Just a little tip: I suggest parking the Brute Farce for the winter months, perhaps in warm storage. If snow gets on anything or anywhere, your looking at frozen cables, water in fluids, locked up steering, brakes locked, wheel bearing problems, wont start, wont idle, etc, etc.
I've also heard that the airbox will fill with snow without much provocation.
Bottom line: Buy a snowmobile for the snow, this quad is in absolutely no shape to handle it. Dont' beleive me? Go ahead, drive through some foot-tall stuff and then check the quad in the morning..... it will be in rough shape.
Old Jan 24, 2005 | 01:43 PM
86LT250RFatty's Avatar
no wory! the only wory is traction when your driving in it [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 24, 2005 | 02:19 PM
hondabuster's Avatar
I put my kodiak away in an unheated garage, and its covered with and packed with snow, and I havent had a problem.
Old Jan 24, 2005 | 02:22 PM
tta583's Avatar
Well from my exploits I would say you are OK. The only time I have ever Iced my AC was when I broke into some mud under the snow and decided I wanted to spray it off. I did not like the mud/ice/snow slurry packed into the inside of the wheels. I sprayed it at a car wash and expected a sheet of ice. I, however, also knew I was going to fire up the heater in the garage to melt it. I was jsut carefull as I realized that I just froze up the plastics which can make that stuff a little more prone to crack. Other than that, no problems. If it is cold enough to freeze the thing solid, well, I am staying inside.
brent
Old Jan 24, 2005 | 06:53 PM
WyoBullRydr's Avatar
I routinely (I can't spell) ride my 04 grizz in snow over the winch and play on the ice pond. I park it outside in the wind with a thin cover on it and I have had NO problems,knock on the wood.
Old Jan 24, 2005 | 07:31 PM
DKNARND's Avatar
You certainly should be a little worried. Snow cakes around the front and rear calipers and freezes making the brakes almost inoperable for one thing. Another thing that happens is the snow will get into your winch and freeze making it impossible to pull the cable out or even turn the know to freespool. And probably the worst that happens is it cakes up around your CV boots and freezes which will tear a boot REAL quickly. Also something to keep an eye on when in the deep snow it will have a tendancy to fly up over the front of the machine and block the airflow through the radiator. On Sunday I was out for a ride and I had to clear out the snow from between the bumper and grill because my temperature started to rise on me.
Every time after I ride in the deep snow I clean out all the snow(as best I can) from around the CV's both front and back when I put it away or on the trailer. Last year I bought a kerosene salamander (torpedo) heater and now I heat the garage after I park the machine to melt most of the snow off.
Old Jan 24, 2005 | 08:35 PM
Thunderbolt's Avatar
I use a torpedo heater too, But remember if you use that you have to keep the heat on until everything melts and dries or you might just as well hose it down. I didn't have any problems with anything freezing, I just don't like it full of snow in case I need to run the heater in the garage while working on something.
Old Jan 24, 2005 | 09:13 PM
OGGYDOGGY's Avatar
SLUGGO I have a 04 griz when I ride deep , I just put it in a garage, mines not heated so I put the salamander to it for a couple of hours and its fine ,melts all the snow and ice off the calipers and around the boots ,also pull the plastic plug at the bottom of the clutch cover and the clear resevior on the intake duct. Thats what I do.
Old Jan 24, 2005 | 09:46 PM
hindtit's Avatar
hey I leave my BF outside ALL THE TIME as in the shop is full. but any way I havent had a problem at all this last weekend did some ice fishing with it and we got to playin in the deep stuff no problem but I would say that any atv with cv joints should be cleaned off it sure bets splittin the boots like on our kodiak but live and learn.
Old Jan 24, 2005 | 11:44 PM
BigBaller's Avatar
It should be fine. If its inside with no heat its still warmer then outside with the wind blowing at it.
