Crossthreaded screw that holds the airfilter on......cant get it off
ok i was taking off my airfilter on my blaster and i was sitting there for about 10 mins with a ratchet unscrewing the bolt till i noticed it wasnt coming out........it is a long bolt as u all no..........but how do i get it out?!!!! help please.... thanx guys
hmmm... mine comes right out.
needle nose pliers? what do u mean? did u strip out the screw?
that is what im wondering if he stripped it out. if you did grab a-hold with a pair of vice-grips and twist it counter clockwise to loosen it.
well i can twist the crew for hours and it wont tighten or loosen..........................
have you tried grabbing it and trying to pull it out?
well then either the threads are messed up( that means pull out with a pair of pliers), or there are no threads( again, use pliers) or, there could be a little nut at the end of the bolt that u cant see and it is juust spinning the bolt, and nothing will happen.
ok let me make my problem clear...........the screw that holds the airfilter on to the airbox...........ya that one..........it is not stripped on the bolt.........its a perfect hexagon.........but i can twist away with a ratchet and it wont come out.........or tighten...........so now i cannot get my airfilter off.........i hopw u no wat bolt im talking about..........the long one.....bout four inches long .........................
sry bout the repeat. |
There isnt a nut on the other side. The bolt screws into a little plastic thing that looks like a triangular cone and the plastic part is threaded. Maby there is one on the bottom of the plastic deal but if you think about it the filter is prety tall and that doesnt leave n e room for it to go down through the little plastic thing at the bottom, that is why it is a cone shape that sticks up. ( at least i think)
