I have a 2000 Blaster that is about two months old. the only mods that I have made to it is adding a FMF Fatty and Powercore II. When I hit near half throttle and then advance the throttle to full there is no change. The engien doesn't seem to change speed from half throttle to full throttle. When you buy a new Blaster is the throttle limiter set only to allow the engine to rev up to half throttle and no further? Or does the change in pipe make it feel that way? On a straight away a fully stock warrior passes me like I am in reverse. Does anyone know what is wrong if anything at all?
Thanks, Anthony |
does it bog down at all?
No, it does not bog down. The engine doesn't sound like it is revving any higher.
Anthony |
From the sound of it, your carb slide may not be opening all the way due to slop in your throttle cable. Check the play in your throttle, thumb or twist. There should be just the slightest play before resistance is felt. Any more & your slide isn't opening fully. If you need to adjust the cable, I have a file to explain how it's done. You can email me for it.
Did u break it in properly? Also make sure its properly warmed up. But it does sound like your throttle cable is not adjusted correctly. Check ans see if ur carb is opening all the way.
Yep.
Check if the carb opens entirely. On my banshee I see a little black spot on the carb slide (actually a small hole) through a samll glass on the side of the carb. If you have such a stuff, check it out. Maybe it's the choke that doesn't turn on OFF. That's what happens on my banshee when I forget the choke on. I gets some rev, but doesn't want to climb very high. Hope it'll help |
When it's in neutral try to rev it up, see if there is any difference from the half ot the full, if that doesn't work try changing the spark plug.
| All times are GMT -5. The time now is 10:41 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
