ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   Banshee pilot's:rich or lean? (https://atvconnection.com/forums/yamaha/213045-banshee-pilots-rich-lean.html)
rotty150 Aug 10, 2005 01:44 AM
I just put on some keihn 35mm pwk carbs and it has a dead spot on the bottom end. If I'm in the power band it does fine at an idle if I punch it it will die or bog out then rev. Mains seem to be fine at 160. pilot is at a 78, air/fuel mix are 1 3/4 out. I am at elevation 2000ft. Does it sound like my pilot is to rich or to lean? thankx
enFORCER Aug 10, 2005 06:38 AM
When I was runing a 350 on gas I had keihin 30mm pwk's.... Biggest mains I ran were 154....
Now having said that, I think your pilots are to big as well... Try dropping them down a few sizes...
My 350 was ported and I am at 472ft. above sea level......
AlkyBurninX Aug 10, 2005 11:42 AM
Drop your pilots to a 55. 160 on the mains is about right.
Christopher Aug 10, 2005 01:22 PM
Your bog can be caused by one of the following:
-Carbs not in sync
-pilot jet clogged or to small
-Needle to lean
Chris
rotty150 Aug 10, 2005 08:27 PM
thankx guys I'll fatten up the pilot, if it gets worse I'll drop it to a 55...
© 2026 MH Sub I, LLC dba Internet Brands
