Need help fixing loose rear brake disc and sprocket
Old 10-21-2000, 08:08 PM
Zorro's Avatar
Hi fellows,
I went riding today (and BTW lost my pipe bolts) and noticed that the rear brake disc and sprocket were loose in rotation way...I mean I can turn them a little whereas the axle doesn't...
What's the deal?
Can anyone tell me what to fix?
BTW, the big nuts on the axle seem to be tight.
Thanks.
Old 10-21-2000, 09:21 PM
Xplor's Avatar
Buy a Polaris!
See ya tomorrow! (if my quad makes it...)
Old 10-21-2000, 10:22 PM
ridzhard's Avatar
I believe that all Banshee's are like that because the hubs "float" on the splines. Mine do and I have never had a problem.
Old 10-21-2000, 11:20 PM
Zorro's Avatar
Do you mean that your disc and sprocket rotate like 5 degrees while the axle doesn't?
Strange.
I forgot to mention that I have a very fast "clac clac" under full aceeleration. Sprockets are new, and chain tension is good...wouldn't the loose sprocket and clacclac be linked?
Old 10-22-2000, 02:51 AM
paulb's Avatar
hi zorro
ther should be no play ( floatation) on the brake disc or the sprocket.
if the axle nuts are properly tightend and you still have play on the sprocket and brake disc the splines ere worn on either the axle and /or the sprocket & brake disc holders.
paul
Old 10-22-2000, 03:28 AM
theox's Avatar
there should not be any play at the sprocket or brake disk.The two large nuts squeeze the bearings,sprocket,disk brake together,,,somtimes they come loose a little bit.The nut on the wheel side is the lock nut,,it must be loosend first,,then you can tighten the other one,,you should have someone hold the rear brake.I use a very large adjustable wrench.A small amount of silicone on the threads between the two nuts will help keep them tight.
Old 10-22-2000, 12:04 PM
Zorro's Avatar
You guys were right.
The big nuts weren't tight enough. I finally found a wrench that fits, I tightened them, and no more loose.
Thanks.
Old 10-22-2000, 11:33 PM
theox's Avatar
The large nuts should be checked pretty regular.Did you notice if your axle had some play before you tightened it? They keep the axle bearings tight..I noticed mine come loose when i race hard on circle tracks. 86 250r 2001 b/w raptor
Jmuddin284
06-28-2017 04:59 PM
Sandman2.0
07-21-2015 09:03 AM
WilliamBos
07-13-2015 02:11 PM
timster911
07-13-2015 01:57 PM
rcappie4
07-10-2015 04:54 PM
Quick Reply: Need help fixing loose rear brake disc and sprocket
