2000 Kodiak keeps blowing AWD fuse when 4x4 is turned on
Id try to find all the connectors, from the switch to the unit in front, and pull them apart and look for water, or corrosion. If things look fine, get some dielectic grease and fill the connectors with it and snap them back together.
If you disconnect the connector at the front diff...then switch into 4wd...does the fuse still blow?
If its Still blowing fuses, after this, then you have to find the pinched wire.
