just stripped the oil cooler drain plug on my raptor 660
Old 11-09-2005, 09:58 PM
themadwarriorrider's Avatar
Default just stripped the oil cooler drain plug on my raptor 660
Old 11-09-2005, 10:00 PM
anyone ever strip the oil cooler resevoir drain bolt, i got some bad luck, the bolt is ok/ however the hole the bolt screw into is striped half way down the hole, how could i fix this problem within two days for hunting season
please help
Old 11-09-2005, 10:29 PM
cloudyfz's Avatar
try to case the threads with a thread chase if its not alluminum.. i really dont know if it is =.. or just apply thread locker and ram the thing in there.. thats what i woould do.. but its propaply not the right thing
Old 11-09-2005, 10:41 PM
it's aluminum, i will try anything at this point im disgusted with my self righty tighty lefty lucy, i don't know why i went the wrong way i was in a hurry and getting ready to go to work
Old 11-09-2005, 10:51 PM
Raptoryfn660r's Avatar
RIP Dear Friend
You might try taking the drain plug to a napa store and see if they might have a self tapping bolt, next size up, that would work.
You will need a new crush gasket also.
Engine oil tank drain bolt is only 18 ft-lb
Old 11-09-2005, 11:03 PM
Curls's Avatar
You will need to install helicoils or some similar hardware. Availabe at my Napa around the corner and most other places that sell high quality hardware.
Old 11-09-2005, 11:12 PM
thank you for the replys tomorrow im off work, ill try doing that, what is hela coils thoug
Old 11-09-2005, 11:16 PM
RIP Dear Friend
Helicoil
Old 11-09-2005, 11:18 PM
it didn't transmit threw the net that's okay though i appreciate the help i will look it up on google
Old 11-09-2005, 11:19 PM
now it did transmit ill read it now thanks
Quick Reply: just stripped the oil cooler drain plug on my raptor 660
