What to do for the motor in my drag bike project
Old Feb 12, 2006 | 09:19 PM
thedieselkid's Avatar
Default What to do for the motor in my drag bike project
I need to start on my motor build now. I am hopping to have my frame back in about 2 weeks. What will make a real good combo. I want atleast 760 cc. I am going to send the head to craycraft, and I am going to bore it out to 105mm. Should I get the nikasil plating. And what should I do for the crank. i was thnking about either the hot rods crank or one of mad man engineering's cranks. Is there anything bigger than a +5mm crank. And what would be a good cam to go with. Thanks.
Old Feb 12, 2006 | 10:03 PM
CTracingraptor's Avatar
if craycraft is doing the motor, maybe you should beg him and try and get your hands on one of his drag cams. they perform very nice.
Old Feb 13, 2006 | 12:06 AM
I am going to have craycraft do the head. I plan on assembling the motor. I am just undecided on what I want to do with it. More than anything I just really need to decide on what crank I am going to use. and how high I am going to go on the compression.
Old Feb 13, 2006 | 01:04 PM
Yamaha660R's Avatar
Your best bet would be to call Bob and talk over the build with him....he could do your headwork and get you most of the parts you'll need for your assembly....he'll also probaly go over the crank/rod options with you as well.
Frisky2050
Apr 9, 2020 11:19 AM
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
