ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   '01 Warrior willn't start (https://atvconnection.com/forums/yamaha/231660-01-warrior-willnt-start.html)
RynoTamer Feb 21, 2006 10:25 PM
Just last year my Warrior decided that it didn't want to start anymore. Thought it was my battery, so I charged it. It started right up and I thought end of story. Wrong. Back to not starting, so bought a new battery, still didn't fix the problem. When hitting the ignition button, I would hear "buzzing/clicking" under the left rear fender. Replaced the celloid there. Same result, quad willn't start. So somewheres there's a short or something. Anyone have any ideas or suggestions. Thanks
jaggers2e42 Feb 21, 2006 10:43 PM
so i take it the motor is turning over..pull the plug and check for fire.
fire,gas and air and that baby should start[img]i/expressions/face-icon-small-wink.gif[/img]
Speedy2222 Feb 21, 2006 11:32 PM
willn't ? are u on crack?
ALSO^^^ if it sat for a while it may have a clogged carb.
recon99 Feb 21, 2006 11:44 PM
Did you take all the heavy cables for the starter and battery off, and clean the terminals? It's easy for these connections to get dirty, wet, and corroded, and cause a bad connection that will make the solenoid buzz.
If all the connections are clean, disconnect the cable from the starter, and put tape over the end or something so it doesn't touch any metal and short out. Then turn the key on and hit the starter button. If it still buzzes you have a short somewhere, if it doesn't buzz i'd put my money on the starter causing the problem.
2000IAWarrior Feb 22, 2006 12:50 AM
well i have had this problem with both my warriors by 2000 back in like 2002 and my 2003 back in 2004...
what i found out to be happend both times.. was my starter was friend.. the brushes stuck.. and burned it up... pull the 2 bolts out that hold the starter on.. and then take it out.. try to turn it over.. and if u want pull the 2 bolt out taht hold it 2gether.. both mine smelled really bad.. and yea it was gone...
jaggers2e42 Feb 22, 2006 01:40 PM
lol..on crack[img]i/expressions/face-icon-small-happy.gif[/img]
counterpunch Feb 22, 2006 04:17 PM
Willn't = won't.
They both say will not.
recon99 Feb 22, 2006 04:45 PM
Originally posted by: counterpunch
Willn't = won't.
Except "willn't" is a made up hillbilly word, not a real word. "Won't" is a real word, and is what us more edumacated people use.
RynoTamer Feb 23, 2006 10:59 PM
I guess my northern hillbilly jargon got all of ya southern belles in quite the dire straights. [img]i/expressions/face-icon-small-tongue.gif[/img] Anyways hey thanks everyone for your help....ride on
jaggers2e42 Feb 23, 2006 11:14 PM
hey,wait a moment there i didn't know the north had hillbillies.well i'll be dang.
© 2026 MH Sub I, LLC dba Internet Brands
