I have a 99 Wolv. and I have a problem with diff. fluid coming out of the breather hose up by the air intake snorkel. I changed the fluid and filled it up to the correct level that was specified in the owners manual and it comes out when I ride. The book said to fill it to the bottom of the threads and that is what I did. That seemed kind of full to me but after some leaked out of the breather hose it still did it. Has anyone had this problem before. I use the Yamaha brand Hypoid 80 sae oil. Thanks in advance for your help.
My friend's did the same thing (wolverine16). I don't think you can stop it. It did it in cold weather the most. He just moved the hose so that it came out the back by the tool box so it would not make a mess under the seat. He also bent his axle like you.
tie both of your vent lines together with a tee and route the line up under the handle bars.
Make sure the vent line is not sticking up into the incoming air stream. It should be just above the rubber shield, trim it or move the block that holds it into place...
DOO800 |
