ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   25's on a wolverine 450 (https://atvconnection.com/forums/yamaha/235452-25s-wolverine-450-a.html)
Trice Mar 31, 2006 09:51 PM
Does anyone have them on one? Did you put a clutch kit on with them? Did it hurt your top speed? Plz can you give me a little review. The only reason I am asking is that i am in the market for one and I can't find any good replacement tire for itthat are 23's.
One last thing is there any way you can make a wolverine 450 run close to 60mph? What mods?
Thanks
Sid
I am new to this site so HI all.
06wolverine Mar 31, 2006 11:25 PM
well i don't have 25s on mine.my stock top speed is 50 mph.With a pipe, K&N,and bigger main jet it might be able to do the 60. I will find out when I get a little $ for the parts.I am craving more speed. i can't help u with the tire situation I am going through the same thing trying to find something that will work better in the sand.
Trice Apr 1, 2006 12:21 AM
Yeah from what everone is telling me is that the top speed is somewhere around 50-53mph and I love the wolverine but I need to be able to run with a grizz or at least keep up with one on the road.The mods I was thinking about are not out yet. (I Think) They may be? I hope they will be in the next year or so.
Cam (WebCam make the #88 grind but I think the #84 grind would be sick)
valve springs
hi comp piston and over bore, (I want it to be a real 450!)
cdi
jet kit
full exhaust
intake
clutch kit
This is just my wishlist.
I think after all that it will run like a raped ape. What do you think?
Sid
Trice Apr 2, 2006 03:14 AM
I have been looking around and does anyone know of any place thats makes a pistons for the wolverine 450? Hi Comp or overbore or maybe even a overbore hi comp piston?
Sid
Quadfather007 Oct 13, 2006 04:04 PM
Ok, I've been searching for a long time now and I've only found one thing. An exhaust for my Quad, yet it doesnt look like it comes with the mid pipe. Its only a muffler, now is 225 for just the muffler too much? How else can I find everything or other ways to mod and get more speed?
thewolv Oct 15, 2006 10:01 AM
I feel your pain. but you shoud know I was told by the mechanic at my local yamaha dealership. CDI box and motor limitations will limit your speed to 50-53 mph you can cheat by adding 25" tires. This adds 5 or so mph this will get you closer to 60 (I got 58 or so on mine when i last ran against my old 660.)
but its going to be guttless as hell. trust me i did and it sucked. so to over come the loss of power I ended up adding a jet kit (dynojet) pipe (GYTR) and a cam (Webcam inc.) and i got my buddie to port and polish the head when he put the cam and valve springs in.
It got a little $spendy$ but it was all worth it!! now i got a little more speed and power than i did before and some more ground clearance.
but you should know the stock grizzly still smokes me but in the trails the little wolverine takes the corners a lot better and hugs the ground better and comes out on top.
does any body have a clutch kit yet? will that kill your top end?
"next project mounting a YFZ 450 shock to the rear for a smother ride"
VooDooYouDo Oct 18, 2006 08:36 PM
Yours only does 50mph? I did 55 with my girlfriend on the back (stock at the time)
I'm trying to find the new ITP TerraCross R/T 25" tire, but no one seems to have it.
What jet kits did you guys use? I don't want to mess with carbs too much.
thewolv Oct 18, 2006 08:43 PM
Dyno jet. but follow the directions exactly or it will run like crap.
miassmaro98 Mar 25, 2007 08:09 AM
WELL MINES WHEN STOCK WENT 52MPN MPH THE DISPLAY.WENT I PUT THE 25" MUDBUGS THE MOST ON SEEN ON THE DISPLAY WAS 46 MPH.NOW REMEMBER THE SPEEDO IS A LIL OFF WITH THE BIGGER TIRES.
MiWolverine Mar 25, 2007 11:41 AM
I have been casually looking around for mods for my 06 wolverine, and there doesn't seem like theres that much out there yet. Mine tops out at 52 mph on a straight away, and i've got it to hit 55 mph down a hill. I also have an 07 grizzly 700, and it smokes the wolvy. If you want to keep up with the grizzly, you will be dropping a lot of money and time into mods.
© 2026 MH Sub I, LLC dba Internet Brands
