New Grizzly help pls
Hi Just ordered a new Grizzly I live in a remote area [tip of Queensland Australia] atv arrives via barge next week.
Can anyone help with any set-up tips and things to check. Nearest yamy dealer is 600 miles away.
Also after run-in period would you recommend using fully synthetic oil? Never owned a Atv before but have had heaps of dirt bikes. Currently ride a KTM 640 ENDURO. Any advice would be great. Cheers
There isn't really much to put togher. Use a torque wrench on the tires at 55 Nm or (5.5 m-Kg). Use the correct grade/ type/ amount of engine oil, front, and rear differential oils. Rotate your handle bars up and torque the stem to 20 Nm or (2.0 m-Kg). And only use engine oil recommended for your engine.
TLC
Utility ATVs
09-16-2015 01:41 PM
