Grizzly easy add-on power fixes
I would start with a EPI clutch kit to help improve you bottom end that you probably lost ( I did ) when you put the bigger tires on and you can get a power end cap that is pretty cheap on E- Bay that will make it sound a ton better and helps a bit on power but not alot. A Uni air filter and a dyno jet kit would also help .....keep in mind that this all works hand and hand all helps some to make a bigger difference once you have it all. If you want to improve the power alot I just installed a Mud buster cam from Hot Cams and that made a HUGE difference. I also ordered a Penland HMF pipe that should really wake mine up even more. I think with all of my mods I probably gained around 10 hp but that is just a guess from talking to the people at hot cams and HMF. I hope this helps you get in the right direction.
