'06 Kodiak - Flashing reverse light while in gear?
I've got an 06 Kodiak, about three months old, that from time to time will flash its reverse light. Happens while it's in Park as well as in gear, both while idleing as well as while hauling *** down the trail. Typically happens for about 20-30 seconds and then the reverse light turns off again. It's definitely not a bad contact or ground as the reverse light flashes at a constant pace, almost seems like it's a diagnostic flash of some sort. Called my local dealer (who I bought it from) and they're pretty much clueless. You guys have any ideas as to what it might be?
Originally posted by: hondabuster
Has the motor been bounced off of the rev limiter, shortly before the flashing?
I know the older raptors and grizzlys had a feature...if the revs were over 3000 for more than 10secs, with out a load (nuetral or park), it would flash the reverse light. It seems to me, it will also flash if the rev limiter is held for 10 secs.
Check out this old thread
here
Or do a search, looking for flash and reverse in itle or body...theres a few threads on it.
here
KimSJoh
14
07-18-2015 07:20 PM
