Rhino, Stuck in 4WD. HELP!
Hey guys i have a 04, Rhino and the problem is that it will not come out of 4WD. I have remove the Servo assembly for the front diff and it and the shift fork are working fine. It is the front Left side tire is locked in with back wheels, the front right tire is free to spin, except for when i put it in 4WD Locked diff it then is locked up with the rest of the tires. Do you guys think it could be the spider gears with in the diff are fubared/
