ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   warrior won't stay running (https://atvconnection.com/forums/yamaha/267278-warrior-wont-stay-running.html)
bamweiser May 23, 2007 02:35 PM
hey folks, my 93 yamaha warrior won't stay running .. checked the spark plug and it looks fine, going to change it anyways. it will start up but die right out afterwards .. sometimes it will staying running for a bit then die out. Sometimes i can rev it right up and it will stay running but eventually die out. check the gas hose to make sure it was getting air .. just cleaned the air filter. It started when i was running some big hills and jumping too. I worked the bike quite hard then at the end of our sess it started acting up. I also have an electrical problem. At first the negative connector was loose so i tightened it up and the neutal light would stay on but now i have to turn the key on then start it but this only works once, if i stalls i have to turn the key off then on again in order to start. anyways hope someone can help, its beautiful out and i can't ride [img]i/expressions/face-icon-small-sad.gif[/img]
royiii May 24, 2007 07:48 PM
I have a 92 warrior and after about 10 min of runing it dies. I think it might be the coil but I don't know how to check it. If you find out whats wrong with your's let me know. thanks
bamweiser May 25, 2007 08:28 PM
replaced coil, plug and carb still same problem .. think its the stator so instead of replacing it i am putting my other engine in
let you know what happens in a couple days
bamweiser May 25, 2007 09:27 PM
this site blows .. no one is nice enough to help out
bamweiser May 27, 2007 03:48 PM
oh and royii it was the CDI box
Raptor450 May 28, 2007 12:09 PM
Sounds like you both have electrical problems. A problem I had with my Warrior one time was a wire going to the CDI in the back had rubbed the frame until the copper was touching the frame and grounded out. It would run for a while and then just die and wouldnt start back unless I shook the bike.
royiii May 28, 2007 11:06 PM
Thanks man I'll check it .<div class="FTQUOTE"><begin quote>Originally posted by: bamweiser
oh and royii it was the CDI box</end quote></div>
© 2026 MH Sub I, LLC dba Internet Brands
