Raptor 700r upgrades
So Im looking at hot cams stage 2..... What else does this upgrade require??? And also how is the power differences??? Is it really as easy as it looks???
Raptor 700r upgrades"></title><script src=
You will also need a stiffer valve spring set,as long as you have the head off get it ported and polished. Well worth the $. Also if you don't already have intake and exhaust, do that. also some re-jetting will be needed.
there will be no spring upgrade required with the hotcams. and i would suggest gettting a stg 3, i seen some dyno tests and it takes very little of the bottom and adds quite a bit up top. and yes it is pretty dang easy to do. make sure u use a slide hammer though. will make life a lot easyier and the power difference will be very nice. what other mods do u have at this point if any?
