Raptor 660 -Engine cuts off, reverse light comes on then off & then motor recovers
[img]i/expressions/face-icon-small-confused.gif[/img]
This question could not be answered by any Yamaha tech I have spoke to..
While riding my 2001 660 Raptor at cruising speed , the motor cuts off, at the same time the reverse light comes on, the motor recovers and then light goes off. this is then repeated. There is no explained reason why. It has the same symptom as if you hit the cut off switch for 3-5 seconds and then turned it back on. No backfire. This happens towards the end of a short riding day. It so far has always recovered to get me back to camp but I am sure one day it may not. An additional symptom is it sputters, like the pkng brake kill switch is on ( which as been removed), when I am climbing hills. Carbs were serviced by Yamaha.
I will stay here till I getthe answer. Thanks
i have a 2004 660. one day i was ridding mine in the mountians. the motor starting turning off and having loss of power for no reason. then it cut out and the reverse light came on. at first i thought it was a bad connection with my CDI box. then about 10 minutes later it did it again. the motor died and reverse light came on. i finally descoved the wire connected to my reverse switch/sensor was not making good contact. it had some moisture/dirt in it. after cleaning it out, it ran great. i hope this helps ya.
Your reverse switch connector is loose. THe reverse switch (a switch that senses when the tranny is IN reverse, not the reverse lever on your fender) is just below the output sprocket on the left side of the engine.
to the guys wondering why the revers light come on when riding
bzdok1234
30
02-23-2016 01:55 PM
KimSJoh
14
07-18-2015 07:20 PM
