troubleshoot 07 wolverine
Old Nov 1, 2007 | 01:21 PM
Piratejonh's Avatar
Default troubleshoot 07 wolverine
Hi all, new to your forum. I have 2- 2007 wolverine special editions. Both are bone stock. About 50 hours on them. Maintenance by stealership as needed. I want to learn to work on these myself. I'm a fairly competant jeep mechanic. One atv has been rolled and drowned. Teenager driving LOL. It still starts easy, idles normally but has no top end. Top speed is about 27 mph by the speedometer. The other one gets about 38-41 mph. I have removed and cleaned the carb (it appeared clean) cleaned the air filter. replaced spark plug, old one had carbon on it. Any ideas where to start? Should I change oil/transmission fluids? They appear clean. Could it be the culprit? And what is the thing on the top of the carb that appers to be vacuum controled?
Old Nov 1, 2007 | 02:05 PM
ctateusa1's Avatar
Ok by drowned do you mean it had too much fuel dumped into the motor or you got it in deep wateR?
If you got it in a creek or anything I would pull the clutch cover on it and see if you have all the grease slung out of the primary clutch, as that will cause the belt to slip and the bike will not get up to speed. As far as the one that gets between 38-41 that is still a little slow, as most of them run about 10-13 mph faster.
Old Nov 1, 2007 | 03:01 PM
Piratejonh's Avatar
Drowned in the water. South Florida summer. Where can I get specific instructions on pulling clutch cover? I pulled the cover off the side with the belt, it was dirty so I cleaned it out and there was some grease as well.
Old Nov 1, 2007 | 04:33 PM
ctateusa1's Avatar
ok that is the right side, you need to pull off the clutch and repack it with some new grizz grease from yamaha , here is a link to how to do everything here
Old Nov 1, 2007 | 05:42 PM
Piratejonh's Avatar
Thank you, I'll try that.
Old Nov 1, 2007 | 07:05 PM
ctateusa1's Avatar
sure not a problem, let me know if you need anything else.
pgamboa
Dec 24, 2023 11:52 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
