boots
i need to know how to make it easyer to shift in boots it seems like my nerf bars get in the way and it makes it hard to shift so help me out
boots
Adjust the linkage on your shifter to bring it farther up, making easier to get your boot under it.
boots
What kind of boots? The full knee-high motocross boots suck on ATVs. You can't bend your ankle in them to shift. The half-boots work good on ATVs.
boots
you can do those or you can adjust the straps on your nerf bars so you can get under it that way
boots
ya i have the o8 full nee thor boots
and i will probably adjust the straps on my nerf bars cus that will probably be the easiest thing to do |
boots
Yup, just keep the netting a little loose on the nerfs. I have Fox Forma Pros and have no problem shifting with a stock YFZ450 shifter.
boots
ya thanks man i already loosend them up now i just need to break in my boots a little bit more
boots
what kind of boots do u have ???just curious because i'd liek to know how well there workign for you
boots
you can also just move the shifter up knotch also...it will make it easier to get under the shifter since the boots are thicker then regular shoes and boots
boots
It still sucks with moto X boots..Even after moving the shifter up and the Wolverine dont have nerf bars,I had to stand up to get the boot under the shifter,Now I just ride with steel toe work boots with knee/ankle protectors ..works great..
