Kodiak Drive Problem...only drives in neutral
Ok guys
just got my kodiak out in the snow and after riding it then putting it away i went to ride again and i could only drive in neutral.....it had no reverse or hi but when i would start it in neutral it would be in gear....any thoughts? thanks in advance Nick |
Linkage out of adjustment? Was the green neutral light on?
Adjust the linkage probably, mine got totally loose so I put thread locker on.
yeah the light was on that and when i would have it in hi or reverse all it would do is grunt like it was trying to go but it just wouldnt it also sounded like my belt was slipping too but im not sure
I have also found out that if the light isn't on neutral then it isn't in neutral, it will still be on the last position it was.
I was in high then tried to get it in neutral and I know the shifter was there but the light wasn't on so it still thinks its in high. |
so you think that my linkage it out of wack but what about my reverse?
or will fixing my linkage fix my reverse too?
are you talking about the rod going from my shifter to my engine case area? or the dashboard area ................ also when i have it in any gear it's always locked up i can push it backwards in neutral (so it says im in neutral) but its hard as hell to move that and now when i get it started when i try and give it gas it stalls me out every time but it will idle fine
any pointers....im to my last nerve about time to take it to the dealership at last resort thanks |
Im having the same problem what corrects it?
I am too! What is the FIX ????
