Blaster steering column
Hello All,
I have a blaster as you may of seen in my previous post that has a camber issue. one front side tire is slightly more angled than the otherside.I can live with that. I also noticed with my front handlebars pointing straight, The tie rod mounts on the steering column is off center. I assume this is bent and cant be adjusted. I can make up for some of the difference if I make on tie rod longer than the other to get the wheel somewhat straight. Is this common or am I being to dam picky*l* |
