yfs rebuild question
Well hi im new to the forums so whats up everyone. i have a yfs 200 that im rebuilding due to no compression. i took apart the head and the cylinder walls were scratched up, the bearing which holds the piston is bad because the piston moves side to side alot and im pretty sure in the combustion chamber there shouldnt be no play. long story short i bought the piston, ring set, bearing,pin,circlips.now im pretty sure this will solve the problem but i noticed that the rod has a lil play to is this normal or should i just get a new one.
fordfaithful21
12-07-2015 05:52 PM
