2002 Raptor 660 Reverse light comes on going forward.
This just started happening. Going forward the reverse light comes on and the engine cuts out like it is triggering a rev limiter. You back off on the gas and the light goes out and power comes back. Did anyone ever have this problem? Thanks.
do a search it sounds like your reverse limiter is kicking in, theres a bunch of info on here of how to fix it...
I found the problem. It was the speed sensor. I took the plug off and cleaned it real good. The ground wire right next to it was frayed. I put a new end on and put it back on. The problem is gone.
good deal...
