Big Bear Ball Joints how loose or tight
A new ball joint is going to have some resistance, but not like that of a car. With use and age, they will get loose. What you are mainly looking for is the amount of "up and down" movement the ball has in the socket - if you have a lot of "up and down", the ball joint is pretty worn out and may disconnect from the socket.
I don't have a lot of play going up and down except where the bolt goes through at the notch on thew ball joint. Like the bolt is too small or the notch may be worn bigger.
pulled it and both look fine .
I think since my wheel bearings in the front are shot it gives a sense of bad ball joint feel..
09-01-2015 11:59 PM
