Wolve won't run?
Hello, new to the forum. I have a 2000 Wolverine. When cold it will start with full choke on. As soon as it warms up a little it quits and then absolutely will not start again untill I let it set 20-30 min then the process repeats. Any help appreciated. My kid are driving me crazy not being able to ride. Thanks.
Wolve won't run?
My first guess would be maybe pull and clean the carb out to be sure you don't have a gummed up carb giving you problems,but if it totally dies and will not restart for half an hour, you may have an electrical problem, do you have spark when this happens? stators and coils can open up when heated if a wire is cracked,so loosing spark after it warms up may be one of those components.
But first, nest time it happens, immediately pull the plug, hook it to the coil wire and lay it against the block, then crank the motor and see if you get a good blue spark (just don't hold the wire, you may get a nasty shock) |
| All times are GMT -5. The time now is 08:35 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
