Clutch Switch or Parking Brake Switch? (1997 Warrior)
i have a broken switch but i'm not sure which one it is. The connector is broken where it goes into the clutch assembly. I'm just not sure which switch it is. Looking down on the assembly it is the top connection. It runs to a connector with a black wire and a green wire. I also need to know what do do with the broken cable. Should I get a new one or bypass it somehow. If so, how do I bypass it? The bottom connector goes to two "bullet" style connectors with one black wire and one yellow stripe wire. I was also having problems with it bogging down when I give it gas so I was going to try bypassing the Parking brake switch. I just need to know which is which. Thanks!
(Yes I know this has been covered on the forum, but there seems to be confusion on which switch is what so i wanted to get a clear cut answer)
yea those two bullet type connectors are for the parking break sensor 90% of warriors owners i know bypass those because they usually cause problems that make it seem as if you have a super early rev limiter on your bike, all you gotta do to bypass them is just plug those 2 bullet connectors into eachother so its just a loop
toonces
10-16-2019 12:11 PM
KimSJoh
14
07-18-2015 07:20 PM
ranvette
07-04-2015 06:13 PM
