97 blaster 200cc no spark
i have a 97 200cc blaster, kick start, and i have no spark. the coil is good (i know this because we jumper wired it from a car battery and touched the wire.) where else could i look? and could it be a faulty on off switch on the handle bars? if so how could i find out? could i by pass it completely by putting a toggle switch?:huh::huh::huh::huh:
Originally Posted by 97blaster200
(Post 2946781)
The stator coil is known to be a "quitter" on these things.... You can buy the whole new stator or just buy a coil for the ignition side..... I had one quit completely while riding it one day.... About a mile later of pushing the damn thing I was almost ready to part with it..... Lucky it was a flat field, cause it was 100 degrees that day. One other thing to do a solid check on, is the ground wire at the spark plug coil under the Tank..... Corrosion will drop your spark if there's enough of it there. |
the ground is deffinately fine. ive checked and cleaned it all up. the last time i rode it, it died, but i didnt think anything of it, because it died loading it on trailer. ill order a new coil and wire, and see if that works. i need new wire anyway.
thanks |
