1997 350 Wolverine help
Old Jul 21, 2014 | 11:05 AM
  #21
Jaster94's Avatar
battery >12v, check inline fuse. slide the red slider kill switch back/forth a few times, look over general wiring.neutral switch illuminating? so there's no power to crank or no power in general on the dashboard? take a voltmeter/ohm meter with you. if the battery is low, jump it with cables from your car/truck. 12v is 12v. if battery is good, can you short the posts on the solenoid with a screwdriver to see if she cranks? how much for the quad?
Old Jul 22, 2014 | 07:30 AM
  #22
bgbk2's Avatar
Default oil leak ?
I have a 2002 prairie , I'm getting oil in the cv boot for the rear drive shaft . I don't think thats normal but don't know much about it. Is it hard fix ?
Old Jul 22, 2014 | 07:43 AM
  #23
Jaster94's Avatar
no, should be just a seal.
2quiker
Mar 22, 2022 08:36 PM
lgardner61980
Sep 20, 2015 01:32 PM
robert301972robert
Aug 30, 2015 11:34 AM
Peter_
Jul 18, 2015 07:06 AM
