stripped\seized bolts and screws.
I bought a 92 warrior evidently with some wear. The draing plug bolt is completely stripped to a donut and the screws that hold in the front pads on the calipers are seized and I've already tried liquid wrench on the screws and grip tite sockets on the bolts. Any suggestions ?
Thanks. |
Originally Posted by Wuwarrior
(Post 3039327)
Thanks. This doesn't seem to matter much on Stainless though..... No Power tools to work the bolt either.... might as well just break em off to start with if you're going to put an impact wrench on it. The mixture is very thin and gets into places the other oils will not, and the acetone evaporates pretty fast leaving behind a lubricating layer of Trans fluid..... |
If you can, weld a nut on the rounded drain plug. I've done this several times and it works well. If the screws were phillips and are rounded I use a dremel tool with a small cut off wheel to cut a straight slot and then use a hand impact to loosen them. Good luck.
Thanks for suggestions guys. I was succesful in getting the screws out but I can't weld a nut onto the plug? Is it possible they aluminum? If it is does anyone have another suggestion?
Thanks a lot. |
(Post 3040875)
Thanks a lot. I've been known to make my own "flats" on a rounded off bolt also. That takes a ton of time and effort, and sometimes no result.... but It's been done. Files and grinders are your friend. I also have a set of left handed drill bits, they do a great job on smaller items, as they heat the screw up as they drill, and sometimes they grab the screw and unscrew it while drilling, removing the screw very quickly.... I think HF sells some short screw extractors that could help also. |
(Post 3040875)
Thanks a lot. Before all that though... I assume you've been trying with a 12 point socket or wrench... Get a 6 point socket and see if that grabs the plug better before you hack it up with a dremel. You may even be able to hammer a smaller socket onto the plug and get it to bite well enough to remove the plug... |
Probably something like this could help too...
Sears: Online department store featuring appliances, tools, fitness equipment and more |
